Vitalik Slivkov свой
Добавлено: 01.01.2008 00:27 Заголовок сообщения: |
УПС! И у меня проблема.
Имеется сервер на FC7 и arvdr-src-20070614.tar.bz2
Имеются карты SS2.6D и SS3 (TT1401)
Код: | [root@gw-home src]# ls -l /dev/dvb/
итого 0
drwxr-xr-x 2 root root 120 Дек 31 22:05 adapter0
drwxr-xr-x 2 root root 120 Дек 31 22:05 adapter1
[root@gw-home src]# |
Интернет на 40Е через /dev/dvb/adapter0 или TT1401
ТВ на поворотке на SS2.6D
Запускаем интернет, а затем ТВ (vdr)
Видем логи
Код: | Jan 1 00:52:40 gw-home vdr: [2814] VDR version 1.4.7 started
Jan 1 00:52:40 gw-home vdr: [2814] loading plugin: /usr/lib/vdr/libvdr-streamdev-server.so.1.4.5
Jan 1 00:52:40 gw-home vdr: [2814] loading plugin: /usr/lib/vdr/libvdr-rotor.so.1.4.5
Jan 1 00:52:40 gw-home vdr: [2814] loading plugin: /usr/lib/vdr/libvdr-reelchannelscan.so.1.4.5
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/setup.conf
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/sources.conf
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/diseqc.conf
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/channels.conf
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/timers.conf
Jan 1 00:52:40 gw-home vdr: [2814] Failed to load translated 'commands.conf.rus' for language 16 (Русский)
Jan 1 00:52:40 gw-home vdr: [2814] Falling back to default 'commands.conf' (if any)
Jan 1 00:52:40 gw-home vdr: [2814] Failed to load translated 'reccmds.conf.rus' for language 16 (Русский)
Jan 1 00:52:40 gw-home vdr: [2814] Falling back to default 'reccmds.conf' (if any)
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/svdrphosts.conf
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/remote.conf
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/keymacros.conf
Jan 1 00:52:40 gw-home vdr: [2814] found 2 video devices
Jan 1 00:52:40 gw-home vdr: [2814] initializing plugin: streamdev-server (0.3.3-pre3-geni): VDR Streaming Server
Jan 1 00:52:40 gw-home vdr: [2814] initializing plugin: rotor (0.1.4): Steuerung eines Rotors
Jan 1 00:52:40 gw-home vdr: [2814] initializing plugin: reelchannelscan (0.4.3): Search Transponders for DVB Channels
Jan 1 00:52:40 gw-home vdr: [2814] ERROR: invalid primary device number: 3
Jan 1 00:52:40 gw-home vdr: [2814] ERROR: no primary device found - using first device!
Jan 1 00:52:40 gw-home vdr: [2814] setting primary device to 1
Jan 1 00:52:40 gw-home vdr: [2814] SVDRP listening on port 2001
Jan 1 00:52:40 gw-home vdr: [2814] setting current skin to "sttng"
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/themes/sttng-default.theme
Jan 1 00:52:40 gw-home vdr: [2814] starting plugin: streamdev-server
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/plugins/streamdevhosts.conf
Jan 1 00:52:40 gw-home vdr: [2814] starting plugin: rotor
Jan 1 00:52:40 gw-home vdr: [2814] loading /video0/plugins/rotor.conf
Jan 1 00:52:40 gw-home vdr: [2814] starting plugin: reelchannelscan
Jan 1 00:52:40 gw-home vdr: [2814] ERROR: no OSD provider available - using dummy OSD!
Jan 1 00:52:40 gw-home vdr: [2823] Streamdev: Listening (VTP) on port 2004
Jan 1 00:52:40 gw-home vdr: [2823] Streamdev: Listening (HTTP) on port 3000
Jan 1 00:52:50 gw-home vdr: [2814] switching to channel 1
Jan 1 00:52:50 gw-home vdr: [2814] info: Канал недоступен!
Jan 1 00:52:50 gw-home vdr: [2814] ERROR: no OSD provider available - using dummy OSD!
Jan 1 00:52:52 gw-home vdr: [2814] ERROR: no OSD provider available - using dummy OSD!
Jan 1 00:52:55 gw-home vdr: [2823] Streamdev: Accepted new client (HTTP) 192.168.0.1:49645
Jan 1 00:52:55 gw-home vdr: [2823] streamdev: closing streamdev connection to 192.168.0.1:49645
Jan 1 00:52:55 gw-home vdr: [2823] Streamdev: Accepted new client (HTTP) 192.168.0.1:49646
Jan 1 00:52:55 gw-home vdr: [2823] streamdev: closing streamdev connection to 192.168.0.1:49646
Jan 1 00:53:17 gw-home vdr: [2823] Streamdev: Accepted new client (HTTP) 192.168.0.1:49647
Jan 1 00:53:26 gw-home vdr: [2821] frontend 1 timed out while tuning to channel 3, tp 211048
Jan 1 00:53:50 gw-home vdr: [2818] frontend 0 timed out while tuning to channel 289, tp 112379
Jan 1 00:54:11 gw-home vdr: [2818] frontend 0 timed out while tuning to channel 463, tp 110723
[root@gw-home ~]#
Таким образом интернет у нас не работает и тарелка не вращается, а при одной карточке все пучком.
Вот конфиг
Код: | [root@gw-home ~]# cat /video0/setup.conf
AudioLanguages = rus
ChannelInfoPos = 0
ChannelInfoTime = 5
CurrentChannel = 1
CurrentDolby = 0
CurrentVolume = 255
DefaultLifetime = 99
DefaultPriority = 50
DiSEqC = 0
EPGBugfixLevel = 3
EPGLanguages =
EPGLinger = 0
EPGScanTimeout = 5
FontFix = courbd.ttf
FontFixSize = 17
FontOsd = arialbd.ttf
FontOsdSize = 22
FontSml = arial.ttf
FontSmlSize = 20
InitialChannel = 0
InitialVolume = -1
InstantRecordTime = 180
LnbFrequHi = 10600
LnbFrequLo = 9750
LnbSLOF = 11700
MarginStart = 2
MarginStop = 10
MarkInstantRecord = 1
MaxVideoFileSize = 2000
MenuButtonCloses = 0
MenuCmdPosition = 0
MenuScrollPage = 1
MenuScrollWrap = 0
MinEventTimeout = 30
MinUserInactivity = 300
MultiSpeedMode = 0
NameInstantRecord = TITLE EPISODE
noEPG =
OSDHeight = 486
OSDLanguage = 16
OSDLeft = 54
OSDMessageTime = 1
OSDSkin = sttng
OSDTheme = default
OSDTop = 45
OSDWidth = 624
PauseLifetime = 1
PausePriority = 10
PrimaryDVB = 3
PrimaryLimit = 0
RecordingDirs = 1
ResumeID = 0
SetSystemTime = 0
ShowInfoOnChSwitch = 1
ShowProgressBar = 0
ShowRecDate = 1
ShowRecLength = 0
ShowRecTime = 1
ShowReplayMode = 0
SplitEditedFiles = 0
SVDRPTimeout = 300
TimeoutRequChInfo = 1
TimeSource = 0
TimeTransponder = 0
UpdateChannels = 6
UseDolbyDigital = 1
UseSmallFont = 1
UseSubtitle = 1
UseVps = 0
VideoDisplayFormat = 1
VideoFormat = 0
VpsMargin = 120
ZapTimeout = 3
reelchannelscan.ServiceType = 2
rotor.Card1 = 2
rotor.Card2 = 2
rotor.Card3 = 2
rotor.Card4 = 2
rotor.DVB-Karte = 1
rotor.EastWest = 1
rotor.Latitude = 436
rotor.Longitude = 424
rotor.ShowInfo = 0
rotor.SouthNorth = 0
rotor.UseGotoPos = 0
rotor.UseGotoX = 1
rotor.Wiederholen = 1
streamdev-server.AllowSuspend = 1
streamdev-server.HTTPBindIP = 0.0.0.0
streamdev-server.HTTPServerPort = 3000
streamdev-server.HTTPStreamType = 1
streamdev-server.MaxClients = 5
streamdev-server.ServerPort = 2004
streamdev-server.StartHTTPServer = 1
streamdev-server.StartServer = 1
streamdev-server.SuspendMode = 1
streamdev-server.VTPBindIP = 0.0.0.0
[root@gw-home ~]# |
Что поправить?
ЗЫ: С новым годом! Форуму процветания, всем новых идей! _________________ Мы кипим, мы парим, но все равно мы не паровозы. |
free-x свой
Добавлено: 04.01.2008 23:49 Заголовок сообщения: |
Код: |
vdr -c /etc/vdr -h
-D NUM, --device=NUM use only the given DVB device (NUM = 0, 1, 2...)
there may be several -D options (default: all DVB
devices will be used)
Frohes Neues |
Добавлено: 10.01.2008 17:39 Заголовок сообщения: |
free-x писал(а): | Код: |
vdr -c /etc/vdr -h
Frohes Neues |
Видели и даже ее использовали, но забыл сказать что так и делал...
Еще мучил ca.conf на сей предмет, но такое впечатление, что данные опции ему по барабану
Попробовать осталось пересобрать заново с минимальным джентельменским набором и по шагам добавляя все больше и больше плагинов.
ЗЫ: А патч http://bigpatch.vdr-developer.org/Patches%20included%20in%20BP/SourceCaps-1.3.39.patch для меня актуален? _________________ Мы кипим, мы парим, но все равно мы не паровозы. |
Bikalexander новый
Добавлено: 25.01.2008 00:56 Заголовок сообщения: |
Помнится тут кто то искал утилитку для управления мотоподвесом в консоле ...... прошу любить и жаловать:
Консольные приложения для мотоподвесов |
Tindtc Гость
Добавлено: 01.03.2008 18:07 Заголовок сообщения: |
Прочитал кучу информации по вдр, в голове полная каша, связи с чем хотел уточнить пару вопросов:
1. Имеет ли смысл собирать вдр на основе НЕ скайстар1 и/или dxr3 и аналогов, а бюджетной карточки+видеокарта (что именно я теряю в данном случае?)
2. Читал что при варианте с видеокартой, изображение идёт чере фреймбуфер, так же видел информацию, что пока не удаётся заставить ФБ работать в режимах, отличных от 3х4. Верно ли это?
3. В последних сообщениях о вдр вскольз упоминались слова о рабочем столе. Нынешние версии вдра используют иксы, или это информация о варианте не stand alone системы?
4. Наверное самый важный вопрос для: сколько времени в среднем уходит с момента начала загрузки hdd до полной загрузки вдр (начала просмотра)
ПС: Прошу не пинать сильно, только закончил разбираться c MYTHTV, несколько раз сталкивался с ситуациями, которые практически сводили на нет мои конкретные идеи, но в тех случаях все проблемы удалось решить. В вдр же, как я понял очень узкая привяза к возможно используемому железу, поэтому не хотелось бы сейчас увязнуть поуши в этом, чтобы через неделю понять, что смысла не было. Заранее благодарен за возможные ответы. |
asd1221 свой
Зарегистрирован: 28.11.2006 Сообщения: 43 Откуда: СССР, Москва
Добавлено: 02.03.2008 00:05 Заголовок сообщения: |
Смысл есть, у меня работает на tt-1401 и acorp ds120.
Я вывожу видео через xine, можно выставить не только 4х3, это есть в настроках, использую иксы, мне так больше нравится.
Грузится все за 55 секунд. я думаю, что будет работать на любом железе.
Рекомендую. |
Tindtc Гость
Добавлено: 02.03.2008 00:51 Заголовок сообщения: |
asd1221, Огромное спасибо за ответ ) начинаю вникать )) |
asd1221 свой
Добавлено: 02.03.2008 02:19 Заголовок сообщения: |
если очень интересно, то могу написать инструкцию, как быстро все поставить до состояния, что бы все показывало. у меня даже есть 80% этой инструкции, только доделать надо.
есть одна проблема - перебороть лень
если надо, пишите |
Goga свой
Добавлено: 02.03.2008 10:35 Заголовок сообщения: |
Конечно же напиши - интересно |
asd1221 свой
Добавлено: 02.03.2008 11:55 Заголовок сообщения: |
Инструкцию буду писать не за один раз, буду дописывать изменяя сообщение. Вроде должно все поставиться и показать картинку. Пробуйте установить и задавайте вопросы, если что не так. Задавать вопросы лучше всего на asd1221@gmail.com, по почте пришлю асю для более оперативных ответов.
Установка arvdr.
http://arvdr.free-x.de/iso/arvdr-0.5.3.iso
тут инструкция http://arvdr.free-x.de/wiki/index.php/Install
Установка нового ядра
cd /usr/local/src/
wget http://www.free-x.de/vdr/arvdr-kernel-2.6.20.2.tar.bz2
tar xvjf arvdr-kernel-2.6.20.2.tar.bz2 -C /
обновление
apt-get update
apt-get upgrade
Создание среды разработки
инструкция http://arvdr.free-x.de/wiki/index.php/Develop-umgebung
apt-get install cvs
установка xine-lib
cd /usr/local/src/
wget http://prdownloads.sourceforge.net/xine/xine-lib-1.1.8.tar.bz2
tar xvjf xine-lib-1.1.8.tar.bz2
cd xine-lib-1.1.8
./configure
make
make install
echo "/usr/local/lib" >> /etc/ld.so.conf
установка Х-сервера
apt-get -t sarge-backports install xserver-xorg
apt-get install xfonts-base
Компиляция ArVDR
cd /usr/local/src/
wget http://arvdr.free-x.de/arvdr/dev/arvdr-src-20070614.tar.bz2
tar xvjf arvdr-src-20070614.tar.bz2
cd arvdr-src
cd PLUGINS
cd src
cvs -d:pserver:anonymous@xineliboutput.cvs.sourceforge.net:/cvsroot/xineliboutput co vdr-xineliboutput
Необходимо отредактировать файл
/usr/local/src/arvdr-src/PLUGINS/src/xineliboutput/Makefile
в нем в 23 строку изменить на XINELIBOUTPUT_X11 = 1
cd /usr/local/src/arvdr-src/PLUGINS/src
rm xineliboutput
ln -s vdr-xineliboutput xineliboutput
cd ..
cd ..
./compile.sh
cd arvdr-src
cd PLUGINS
cd src
cd xineliboutput
make install
echo "xv:2:respawn:/usr/X11R6/bin/X :0" >> /etc/inittab
Настройка VDR
продолжение следует. |
Tindtc Гость
Добавлено: 02.03.2008 15:20 Заголовок сообщения: |
Огромнейшее спасибо за инструкцию, вечером буду пробовать, а то информации очень много скопилось за время существования вдра и тяжело сориентироваться, что актуально на данный момент, а что нет. |
Aquila ____________
Добавлено: 02.03.2008 21:47 Заголовок сообщения: |
asd1221 писал(а): | буду дописывать изменяя сообщение |
Лучше продолжения оформлять новыми постами... _________________ --= Aquila non captat muscas =-- |
asd1221 свой
Добавлено: 02.03.2008 23:12 Заголовок сообщения: |
в папке /etc/vdr/config/ у меня 3 файла.
sc.conf
vdr.conf
Код: | PLUGINLIST="sc xineliboutput extrecmenu reelchannelscan mp3 femon radio"
USE_INTERNAL_IR="no"
METOD="acpi"
START_FBTV="no"
START_BT8XX="no"
START_EM8300="no"
START_VDR="yes"
OTHER_OPTS=""
LOG="/dev/tty9"
xineliboutput.conf
Код: | PARAM="--local=sxfe --video=auto --audio=alsa --fullscreen" |
Так как у меня нету дисеков, долго думал, что писать в файле diseqc.conf. На форумах ничего не нашел, а то что написано, сильно меня запутало. Оставил его пустым, все работает.
Из настроек пульта я только скопировал lircd.conf с сайта lirc.org. У меня пульт от MCE, завелся сразу.
Была одна проблемка с пультом. Когда запускаешь из под xine, он начинает вместо пульта обучаться работе с клавой. Вроде победил так: в файле remote.conf после обучения пару строк с упоминанием о клаве:
Код: | KBD.Up 00000000001B5B41
KBD.Down 00000000001B5B42
После удаляем все строки с упоминанием LIRC и перезапускаем. Вроде пульт должен нормально учится. Хотя могу ошибаться. |
alxan новый
Зарегистрирован: 24.12.2007 Сообщения: 4 Откуда: Вятская губерния
Добавлено: 04.03.2008 19:08 Заголовок сообщения: |
Всем доброго времени суток! Вопрос чайника.
Поключил к усб "глаз" от скайстара(пульт TTS35AI). После монтирования усб-устройства пульт заработал(правда не все кнопки правильно работают). Пробовал отключал лирк, стирал файл lircd.conf, а пульт всё равно работает. Я понимаю конечно, что лирк работает с com глазом, поэтому он здесь не причём. Тогда какой модуль управляет моим пультом и где нужно смотреть, что бы пульт работал правильно.
И ещё, а если питание глаза оставить на усб, а USB D- подключить к ноге кома №5(земля) и USB D+ подключить к №1(DCD) будет ли пульт в этом случае работать через лирк. Я почему спрашиваю, в принципе я прбовал и пульт не работал. Мне нужно знать можеть я с лирком не разобрался или это по принципу полный бред. С уважением. |
asd1221 свой
Добавлено: 04.03.2008 20:45 Заголовок сообщения: |
А ты пробовал настроить лирк на этот пульт?
Я думаю что ч комом ничего не выйдет, там же передаются юсб команды.
Как проверял, что пульт работает? |
alxan новый
Добавлено: 04.03.2008 21:18 Заголовок сообщения: |
У меня просто пока нет глаза чтобы лирк спаять. Пробовал использовать датчик от авермедиа тв тюнера, но ничего не получилось. Я думаю сам датчик мёртвый. У меня тоже такая мысль была, что у этой связки от USB скайстара какая то своя система команд. Но тогда посредством чего этот датчик(когда он сидит в USB) и пульт видит arvdr. Где и что править чтобы пульт себя вёл адекватно(работают клавиши переключения каналов, вызов меню же сидит на кнопке "муте" и т.п.) |
asd1221 свой
Добавлено: 05.03.2008 10:14 Заголовок сообщения: |
Если на кнопке "муть" сидит меню, то скорее всего, пульт прикидывается клавой. Попробуй из файла remote.conf удалить все и обучить VDR заново. |
alxan новый
Добавлено: 05.03.2008 22:46 Заголовок сообщения: |
Спасибо за подсказку. Ты прав. Скорее всего что vdr эту парочку определяет как усб-клавиатуру. В программе "коды клавиатуры" посмотрел: кнопка "муте" определяется как клавиша "М"(меню). Сейчас просто коды всех кнопок поснимаю и в remote.conf поправлю. Для эксприментов думаю пойдёт, а так конечно надо лирк цеплять.
Вчера поправил remote.conf, в принципе всё заработало. Единственно при загрузке не всегда в автомате усб монтируется(да и бог с ним). Сегодня выпаял датчик из аналогового рессивера, опробовал лирк(пульт оставил тот же). Лирк вешал и на com и на J2, пульт везде ведёт себя адекватно.
По случаю хочется выразить огромную благодарность за освещение вопроса FREE, BNX, Альяно. FREE отдельное спасибо за дистрибутив arvdr.
Последний раз редактировалось: alxan (06.03.2008 13:26), всего редактировалось 1 раз |
Tindtc Гость
Добавлено: 06.03.2008 00:57 Заголовок сообщения: |
эхх а мне видимо не судьба в ближайшие дни попробывать это чудо, единственный "свободный" винт приказал долго жить. По случаю хотел поинтересоваться, возможна ли установка дистрибутива вдр без полного убиения первоначальных разделов? |
BNX модератор
Tindtc Гость
Добавлено: 06.03.2008 12:49 Заголовок сообщения: |
Есть, читал, но установка вдр на рабочий (полный) дистрибутив, теряет для меня смысл по причине уже имеющегося работоспособного mythtv. |
BNX модератор
Добавлено: 06.03.2008 14:45 Заголовок сообщения: |
Tindtc писал(а): | возможна ли установка дистрибутива вдр без полного убиения первоначальных разделов? |
Хм... Тогда могу посоветовать сначала установить debian в минимальной конфигурации, пользуясь соответственно его инсталлятором. После чего распаковать архив с CD ArVdr содержащий дерево дистра (чейто-там.tar.gz) _________________ Arvdr & XBMC, DM500 & 800HD, UFS910, CubeCafe, 90е to 9е, Stub HH100 & Mot. 2100, Toroidal & Of. 120 & 110 & 60
asd1221 свой
Добавлено: 06.03.2008 15:07 Заголовок сообщения: |
А разве arvdr не дает возможности выбора? Хотя я могу и ошибаться, но дистриб устанавливается через syslinux, а там есть возможность выбора. |
alxan новый
Добавлено: 10.03.2008 12:24 Заголовок сообщения: |
Моя эпопея по освоению arvdr-0.5.3 продолжается. С картой DVB-S-full-featured-card(TechnoTrend DVB-S rev 1.5) особых проблем не возникло(я так понимаю всё изначально настроено под такой тип карт), даже хитрый плагин получилось запустить.
Сейчас же хочется попробовать SS2 rev.2.6D с програмным декодированием потока(GA-7ZXE Athlon 1000MHz, Geforce 4 MX440 8x64Mb DDR, 2x256Mb DDR).
Скажите на моём железе будет работать софтдевайс?
Почитал вики, форум, в голове полная каша. Как я понял в этом случае нужно сначала активировать фреймбуфер и софтдевайс(всё сделал), в /etc/vdr/config/softdevice.conf указывал различные параметры, но на 10-й консоли всё равно чёрный экран. В вике по софтдевайсу говорится об опциях в XF86config(поиск командой find результатов не дал). Если эти опции актуальны, подскажите где лежит этот файл. |
free-x свой
Добавлено: 24.06.2008 15:17 Заголовок сообщения: [АНОНС] Паблик Бета Тест ArVDR-0.7 aka VeDRubuntu |
Комманда ArVDR выпустила в свет публичную Бета дистра.
Отличия/Особенности:
Как База для дистра используется Ubuntu
Пакеты с ArVDR устанавливаются поверх базы
Требуется подключение к Интернет для установки
Возможны различные варианты для вывода: FF карты, dxr3, softdevice, xineliboutput
http://www.forum.free-x.de/wbb/index.php?page=Thread&threadID=86 |
