alsp новый
Зарегистрирован: 28.03.2007 Сообщения: 1 Откуда: Великий Новгород
Добавлено: 28.03.2007 17:00 Заголовок сообщения: SM3D22 - угол 6 градусов между конверторами |
Тут как то проходил вопрос о сбросе сабжа... Может кому пригодится (вычитал на иностранном форуме):
Цитата: | Hi.
This shift is factory set and is not meant to be changed by customer. But anyway if you would like to change it, you must sent a special non-DiSEqC command string to the motor. This can be done by some manual string sending device, i.e. SkyStar2 PCI card or any DiSEqC generator.
If you can get any of these devices, connect motor to it and send custom made string E031A078002B (GREEN!! led on the motor must blink) and then E031A07900EF (GREEN!! led on the motor must blink). From that moment on you have zero degree LNB shift.
Best regards from Slovenia,
Ales Oman
R&D department
Sat Control d.o.o.
Pozenik 10
4207 Cerklje na Gorenjskem
Slovenia, EU
tel: +386 4 2816219
fax:+386 4 2816212
web: www.sat-control.si
email: development _at_ sat-control.si
